1979 sportster ignition replacement
Hello I recently purchased a 1979 sportster 1000. I thought it would have points but it has an electronic system in it. I'm not familiar with any of the electronic ignitions at all. I'm looking to either replace it or upgrade but I'm not sure what I would need to do so. I attached pictures of what I have installed currently. Any recommendations would be greatly appreciated.
Received 21,983 Likes
The following 2 users liked this post by CoolBreeze3646:
Rabbigolem (11-07-2021),
TwiZted Biker (11-04-2021)
that is right on mr. 88
it also was problematic with the pick up sensor melting or going bad. if you have issues, clean it up well since iron filings or corrosion on the cup will affect the hall sensor.
i use the compu-fire in my 1974 which uses the mechanical advance but most just use the ultima system which i use on my 01 sport. they can be a hit/miss as i had one go south but i do push its limits, the compu-fire has been kicking since 1975 with nearly 200k mile.
the mikuni vm38 carb is a good replacement, been have it on my 74ch since 1975 since i broke the original taking the front end off a 1972 chevy impala, no plastic bumper either.
Received 5,424 Likes
