Intermittent problem with 2012 FLSTN Deluxe
Old 10-25-2021, 05:44 PM
MyFavRk's Avatar
MyFavRk
MyFavRk is offline
Received 6,481 Likes on 3,902 Posts
I got to thinking about when you said you opened the gas cap and the bike started , I'm not sure , but it wouldn't hurt to check the tanks vent hose for a blockage . # 29
https://partsfinder.onlinemicrofiche...ANK%20ASSEMBLY
Old 10-26-2021, 02:20 PM
JAMDeluxe's Avatar
JAMDeluxe
JAMDeluxe is offline
Good idea!
Old 11-01-2021, 07:02 AM
MyFavRk's Avatar
MyFavRk
MyFavRk is offline
Any updates on your progress ?
Old 11-01-2021, 10:07 AM
JAMDeluxe's Avatar
JAMDeluxe
Still waiting on parts...
MyFavRk (11-01-2021)
Old 11-05-2021, 02:45 PM
JAMDeluxe's Avatar
JAMDeluxe
Ok, got the parts. Ran into some additional stuff that needed fixing as well. So here's all that was replaced:
  1. New front tire
  2. Rear and front brakes
  3. Fuel pump
  4. Gas cap
Went through the electronics including fuse box; checked and cleaned all the connections. Vent hose was clear.
Took it out for it's maiden voyage after all this and not even 5 miles into the ride, it died. Now throwing a B2119 trouble code: fuel pump output overloaded. So Jim is going to check and see if he did something wrong during the install of the new fuel pump.
Old 11-05-2021, 08:16 PM
MyFavRk's Avatar
MyFavRk
MyFavRk is offline
After you check the connections to the fuel pump , check and clean the connectors on the bcm ( #9 ) and ecu ( #5 , if you have abs ) . Hopefully it's not a bad bcm causing your issue .
https://partsfinder.onlinemicrofiche...UIT%20BREAKERS
Do you recall if the fuel pump is priming when you turned on the ignition after it stalled ?
Did you disconnect the quick release from the tank to the tb during the install of the pump .
Max Headflow (11-05-2021)
Old 11-05-2021, 10:46 PM
JAMDeluxe's Avatar
JAMDeluxe
Jim read your response and will check out and clean the connectors on the the BCM (agree about hoping it's not that!). No ABS so #5 is n/a.
Did not pay attention if the fuel pump was priming on restart.
Jim did not disconnect the quick release.
As always, thanks for the guidance. Onward and upward!
MyFavRk (11-06-2021)
Old 11-06-2021, 09:51 AM
Max Headflow's Avatar
Max Headflow
Max Headflow is online now
Received 6,009 Likes on 4,062 Posts
Since you got a code that hasn't happened before and it's in the area of the work, check the work.
The following 2 users liked this post by Max Headflow:
FLTRI17 (12-10-2021), JAMDeluxe (11-07-2021)
Old 11-11-2021, 06:24 PM
JAMDeluxe's Avatar
JAMDeluxe
Ok, when Jim drained the tank, he found the rollover valve hose was cracked. Replaced that, put it back together. He took it out for a 30 minute ride yesterday with no issues. I took it out today and no problems. We're taking our bikes out for a ride to Tortilla Flats for a longer ride. But it sure seems like we might be fixed now!
Max Headflow (11-11-2021)
Old 11-11-2021, 06:53 PM
MyFavRk's Avatar
MyFavRk
MyFavRk is offline
Glad to hear you may have potentially found the issue , sounds like you did .
Enjoy your trip , ride safe !
Quick Reply: Intermittent problem with 2012 FLSTN Deluxe
