Idle up to 3K and No Throttle Response, Some Trouble Codes
I was getting onto the freeway onramp and got on it with the throttle all the way open until about 75 or so when I merged onto the freeway.
When I backed off the bike was stuck at about 3,000 rpm. It would not go up or down no matter how I moved the throttle. So I made it home which was interesting stopped at lights running at 3,000 rpms and people looking at me like I am crazy lol.
I started it a few times and back up to 3,000 rpm. Then finally it settled down, but after a bit now it is around 2,000 rpm.
The codes are as follows:
P0522 Engine Oil Pressure Switch/Switch Shorted Low
P1511 ETC Power Management Mode
P1514 ETC Airflow Error
P2101 ETC Actuation Error
The bike is a 2018 Road Glide Special with about 10,000 miles on the clock, so not many miles. Any ideas about what I am in for? Thanks!
Hello and thanks. Bars are stock, no changes there. After I cleared the codes the next day and took it our for a quick ride, it appeared to be normal again. I am going to try and recreate the conditions at various rpms to see if it reoccurs, it is a little unsettling to not know what is up and that it can reoccur. No new codes have popped up but I will report back after some longer rides at wide open throttle settings.
sangbro
2018+ Softail Models
04-15-2020 05:35 AM
CliveP
09-30-2018 12:11 PM
