setting idle on 07 sg
RE: setting idle on 07 sg
Not that I've been able to see. It only modifies the injector duration and spark timing signals so unless you want to get pretty creative with those (which I don't recommend) you'll have to investigate the underlying cause and remedy it.
Did you set the throttle limits when the engine is up to temperature?
It's entirely possible to adjust the idle speed. SERT will do it, but that's a rather expensive proposition for just the one effect. I'd bet the dealer could do it with their computer interface but also that they wouldn't. Also, the replacement ECUs (TMAX and DTT) no doubt can do it. It's just that any of the piggy-back units don't "go there" with their adjustments.
ORIGINAL: Lodi Customs
...and regardless
of what you do to tuning,, PC or SERT, the computer will still target 1050
...and regardless
The only way you can change the idle speed with a PC-III would be to either give it so much fuel it barely runs or maybe to take so much away it gets hot enough to make the bike's ECU lower the speed in an attempt to cool it some.
The PC-III does not control anything except fuel and timing amounts.
