Twin cam ignition timing.
stevec1966 (06-14-2021)
Agreed, I had to set mine back ah higher Kpa's because in data logging I saw spark knock detected and the ecm dialed back the timing a couple of degrees.. Everything is based on load and throttle position..
In for the sub on this one!
Been doing some timing tuning on my TC88 and I'm trying to figure out where it's happy, safe, and still feels good when twisting the throttle. I've got a Tmax which allows for easy adjustments but working my way up slowly, and from the lower RPM/throttle settings first, so as not to (hopefully) have any issues. A LOT of varied information on the web, so I'm quite interested in what the brain trust has to say pertinent to the OP's question.
Thanks for asking it!
You really should start your own thread under a T-Max heading to get the proper assistance.. I never used one and am currently using a PV. And depending on engine mods would determine timing curve. Also that 34 tooth trans pulley can load the motor and lug so you'll have to be careful when setting the timing curve..
swampking
02-02-2011 06:32 AM
cwilks
10-04-2007 10:36 AM
