SE race tuner xl1200
RE: SE race tuner xl1200
ORIGINAL: HDWRENCH
Well touse it you would have to have a EFI sporty and that is not out yet
That being said, yes I have used it. What do you need to know that I didn't already explain from the other thread concerning your carb fuel issues? The race tuner will NOT compensate for a poorly tuned carberator.
Well I have a few questions, in some articals I have read they state the 2004 1200c uses high flow heads, high compression pistons, and high pro cams. Is this correct? If so, the sert has two base maps for the 1200, 1st 1200cc stock comp. and 2nd 1200cc with stock comp. and se cams. which should I use? are "high per. cams" the same as SE? My next question is What exactly is it you are doing when you edit the spark table, What happens when you raise or lower the values. Thanks
ORIGINAL: am7010
