SERT Map to Revert to Factory Settings
My SERT came in yesterday so I installed my Stage 1 air filter kit and D&D pipes and downloaded the appropriate map (can't remember which one) and I am impressed! Can't wait until I can get it tweaked on the dyno. Anyway, if I wanted to reload the factory maps, is there any way to do it? My plans were to upload the factory maps, save them to a file, then download the new maps. I thought there would be a way to upload the current ECM configuration with the tuner software but I only saw the download option. So I threw caution to the wind and did the download. Can I ever go back?
07 Softail Custom FXSTC
RE: SERT Map to Revert to Factory Settings
As you have found out, there is no way to pull an existing configuration off of the ECM. It is one way only, download TO the ECM. That said, you really do not want to go back to a stock calibration file anyway now that you have installed your A/C and pipes. You should stick with the calibration file that you selected from the canned calibration files provided with the SERT and use that as your base line.
07 Fatboy
04-27-2007 01:52 AM
