Adjusting the Idle on Delphi EFI
Old 07-31-2007 | 04:29 PM
ScooterJammer's Avatar
ScooterJammer
Default Adjusting the Idle on Delphi EFI
I'm sure this is a stupid question, but I'm going to prove it and ask anyway. Once you complete all your performance mods to your '04 or greater Delphi EFI bike, e.g., A/C, Exhaust, PC or SERT, Cams, Headwork, etc., and then have it Dyno'd at your favorite shop, do you have to have the idle adjusted separately?? I've read in the "manual" that only H-D Dealers with a "Scanalizer" can properly adjust the idle speed on an EFI H-D? Doesn't having your bike Dyno tuned pretty much negate the need for this step or is there something I'm not getting?? I could fill-up a book on what I don't know about Fuel Injection.
ScooterJammer
Old 07-31-2007 | 04:37 PM
Doc 1's Avatar
Doc 1
Default RE: Adjusting the Idle on Delphi EFI
You can adjust the idle with the SERT program....no need for the Digital Tech or scanalizer.
Old 07-31-2007 | 07:47 PM
ScooterJammer
Doc1...Thanks for the reply. What about PCIIIUSB?
ScooterJammer
Old 07-31-2007 | 07:51 PM
Doc 1's Avatar
Doc 1
With the PC the Digital Tech will be needed....thats at the dealer.
Old 07-31-2007 | 09:27 PM
ScooterJammer
Doc 1...Thanks again. I see you work at an HD Dealership, I'm curious, approximately how much time is required to perform an "idle adjustment" or does it require a complete factory tune-up? Or, ...something more involved? I'm just looking for a ballpark of time to estimate how much $$$ I'll be looking at.
ScooterJammer
Old 07-31-2007 | 11:35 PM
jmetro's Avatar
jmetro
It takes them literally 2 sec once hooked up.
Old 08-01-2007 | 09:52 AM
ScooterJammer
jmetro...Which means the Dealership will charge me at least .5 hours labor, I presume no material.
ultraclassic53
05-09-2015 01:39 AM
Getyurmotorunnin
11-27-2009 12:03 PM
hdforme
09-25-2007 01:58 PM
TickTock
02-25-2007 11:05 PM
Russ
04-27-2006 06:18 PM
