TechnoResearch VCM-TR4
Decided to purchase the Centurion. It is the full version but a per-bike License. This Tool is way over my head. Software insatlled updated and License Number entered. If any of you have experience with it I am listening.
My main reason for having it was the ability to disable and enable the BAS aka trike mode and the ABS bleeder function. However with a tool like it in your hands how can you not explore. HD is changing again and I just do not want to be a slave to them.
Thanks for replying . I am sure I will . loaded software on one of my laptops . nee to make sure i am using the correct cables. My main task is I want to see where ti disable the BAS. AKA trike mode.
EDIT: found the information . In the software
I think your comments on the TTS are very misleading. TTS only prevents the ECM tuning from being changed by anyone other than the owner. They can change anything they like back and forth including returning to how it was prior to using the TTS unit. Since the OP was looking for BCM functions the TTS unit has nothing at all to do with those.
