25% gain in mpg
25% gain in mpg
The following relates to UK gallons which are a slightly bigger volume than US gallons, but the percentage increase would be the same for both.
My stock 07 RK Classic with 7500 miles on it was getting about 40-42 miles per gallon, town, open road (80mph), 30's, etc.
I stuck on a ANBS, Screaming eagle pipes and SERT, loaded a canned map, increased the fuel via the clb tables and sucessfully reduced the heat.
Outcome is I am now getting 50 - 52 miles per gallon for the same type of mixed riding.
All I can figure is that the stock AC and pipes were really choking her up, and she was not running efficiently.
Nice bonus.
WB
Nice bonus.
WB
RE: 25% gain in mpg
ORIGINAL: genedjr
I am sorry - add more info.
ABNS?
SERT?
Explain to this n00b.
...gene
ABNS?
SERT?
...gene
SERT = Screaming Eagle Race Tuner (allows ECM to be downloaded with different settings for different set-ups, allows error code reading, and data recording so you can see what is happening in several diferent areas, eg., engine temp, air intake temp, AFR (air fuel ratio), ingition advance etc. etc.
A search of the site will give more info than you can shake a stick at.
WB
RE: 25% gain in mpg
ORIGINAL: ubreal
how much did youincreased the clb tables is it ok if you post that table I was thinking of doing the same to see if my mpg would go up. but I do not know how much to increase clb table did you increase all the cells?
I dont think that alone will do much to the mpg, in fact it should make mpg go down, its the fact that the motor breaths better now and is using a completly different tune to standard.
Dont forget that 1 UK gallon is 1.2 US gallons
WB
RE: 25% gain in mpg
ORIGINAL: WildBill2566
Nice bonus.
WB
Nice bonus.
WB
