DFO,Slipons and Decel Pop
I put the RevTech DFO on to combat the HOT running condition with good success I think. Then I added the AN Big sucker. Still all is good. The first of this week I added Rush 2.25 slipons. Love em, sound great, but now I have decel pop. I have ajusted the DFO per RevTech's instructions.
Anyone with the DFO and similar set up have any tips on how to adjust to eliminate the pop.
Thought I would ask here first. I will probably call RevTech next week.
RE: DFO,Slipons and Decel Pop
richen up the low to eliminate decel pop, but with a DFO, you cant just adjust where it makes it pop, you also adjust where you ride most of the time. so buck up and buy a good fuel processor like the PCIII, SERT, or FUELPAK so that you can actually adjust your tuning.
Call ole George up at Dobeck they make the TFI but they are sold under other names. When your running a mufflers that has a straight thru baffle the the decel pop is hard to get rid up. You might try a smaller baffle. If all your doing is changing mufflers and air filter the DFO will work fine. Sometimes you just have to keep tinkering with it to you find that sweet spot. They have worked fine for us.
These directions are much better that the ones that come with the unit, IMO.
http://www.harleyhog.co.uk/dfo.htm
I could tune the decel pop out of drag pipes...........but not with a DFO.......with the slip ons, you should have used a high temp silicone when putting them on, to make sure they seal up, as most clamps aren't wide enough to cover the clamp cuts in the muffler. anti seize just blows out of these if you use that instead.
ORIGINAL: lschultz
I may have to "buck up" and buy a "good fuel processor", or go to smaller baffles, which I don't think is an option. The mufflers sound really good.
