sportster 1200 timing
#31
That advance at 80-100 kpa will give you trouble, you're running WAY too much advance there.
I did a 2019 1200 sporty the other day on the dyno, usual stage 1, the bike was flashed on the dealer with a stage 1 map. It had like 6-7 degrees more than the engine wanted in the WOT area, the timing map was just stupid as best.
The timing was so way past MBT than the engine picked up 10 horses by pulling timing in the higher areas, it wasn't pinging badly mainly because the fuel quality over here is awesome but that engine on a bad gas tank would be catastrophic
Tuning spark advance without a dyno can end very bad, and even more with sportster that lacks proper detonation/autoign sensors. (The CAN sportster do detect knock but the ECM doesn't pull any timing, atleast based on my experience)
Now that sarcasm is outta the way. Let me start off by saying that i do sincerely agree with what u said.
As mentioned in my previous posts, the Spark table i posted above is just a reference that one can create their own...'given one knows what he/she is doing.
Im sure as a dyno guy, u know an 883 can get away with more timing cos of the lower compression. My posted spark table from my J1850 Fp3 (more on that another day) has been refined over several months to smooth out the kinks. Yes this is all Butt Dyno, ...'but it jus works well for my stg 1 setup, running my own custom made baffles in a hacked pair of stock mufflers.
Which brings us to the variables.. Intake, Exhuast, Tuner, Fuel, regional climatic conditions (Temps, Altitude, Humidity etc) and the Rider himself. Im not looking for Peak numbers, Jus want a smooth ride. Plugs look right, sounds healthy, no excessive heat, good mileage, no detonation in hot weather or WOT... #tuning goals achieved.
The Stg 1 tables below are a great example. WOT region of the PV map aside, I've never had good results at lower rpm with 20° of given timing of SEPT map (it always had pinging or plug fouling with excessive fuel CL/OL). Yet lot of ppl here run the same Map jus fine. Yes my Fp3 also was a factor.
So you see, how the theory of one doesn't always correlate to the practical implications of the other.
#32
Well then, lets jus quickly call Harley and DynoJet abt running excessive timings in their Maps, that are available worldwide before some more engines explode.
And of course, those engines are true living animals that changes based on a million variables, what is good for you may not be good for me, still I wouldn't run 40 or 41º of advance @6000 above the 70kpa zone
And about DJ and HD tunes.. god knows why they are running those stupid timing values in some areas, atleast we know that bikes doens't explode because of that but it is far from optimal.
#33
I am with both of you on this timing and fueling none of it makes much sense in the real world but I am still working on it. I have since moved from about to sea level to around 600ft and with the hills and cooler temps things don’t seem right. I don’t think it’s in the map or fueling anymore though. I am nowhere near the timing being able to produce this rattling I hear under acceleration near the front of the engine. I believe there is something going on with the primary which sucks cause the bike has 700 miles on it. So into Harley it will have to go. I really don’t trust them though to be honest. I haven’t found much luck with them and I wasted money on warranty they might not honor now. Even though I made no changes that should effect the primary drive. I may just go ahead and service it myself and see if it sounds better worse or same.
