17 103 head porting
17 103 head porting
Hello all, I have a 17 FXDL 103. I am upgrading. TTS 150 cams, S&S lifters, S&S adjustable pushrods, and a HPI 55MF TB. My question is, can/ should I port and or polish my heads? Will it make a difference? I can see that there is a difference in diameter of the head and the new TB. Just wondering before I put this thing back together.
thanks
thanks
thanks
thanks
You would've gained just as much or damn near by just some minor porting of the heads and stock 50mm throttle body. I know that's the route I'm going when my heads come off. Too big and you'll lose velocity and low end will suffer for a little more peak hp on a dyno.
I'd make note of your torque curve before and after.
If you plan on doing your own heads, replace the valves with AVnV 1.850 intake and 1.575 exhaust 7mm valves. Cut the throat on the intake valve seat to 0.050 larger and have a good valve job done. 35 to 37.5 degree top cut on the valve will help. AVnV valves will need new keepers and spring collars IIRC. Clean up the ports.
guesscrazy
Engine Mechanical Topics
07-08-2016 06:29 AM
