May 2001" FLHTCUI Diagnostic Trouble Codes
Turn on the power and listen to the gasoline help
Press to start, spark plug without ignition
Pressing the mileage reset button fails to display the fault code
Can't the external computer display the fault?
Has any car friend encountered this situation?
Thank you
Thank you
Thank you
Thank you
External computer??
On this model....fault codes come through flashes of the check engine light. Not the odometer.
Computer codes are accessed by toggling either the ignition switch a few times. IIRC the procedure is to go ON/OFF/ON/OFF/ON with the switch ending in the ON position. if done correctly, the check engine light will flash rapidly followed by a slower sequence of flashes. Each "sequence" is a two number code, with IIRC one second between the first and second numeral sequences (it takes a bit to see what Im talking about, dont worry, the codes recycle if you miss it the first time around). Do a search on the forum for Magneti Marelli codes and you will find a list of what the number codes mean.
