1999 Dyna Lowrider Will not start. Possible ignition module?
I have a 1999 Low rider with 27k on it. The bike has always started right up with no issues. The other day I went to go for a ride, the bike fired right up and ran for about 3 minutes while I moved some stuff around in the shop. I went to hop on it and it sputtered and died. Upon trying to start it again i had to feather the throttle like crazy to get it to start but I could not keep it running. Now the bike will crank over all day with spark. I have an inline spark tester that shows consistent spark in both cylinders. I have removed the carb twice and cleaned it setting everything back to where is was before taking it apart. I checked the vacuum shut off valve for the gas and that works as it should. I replaced the crank position sensor being I had one laying around. New battery, plugs. I have the ignition module off and the coil off at the moment trying to test them. Can you have weak spark that would not ignite the fuel fully? When you crank the bike over you can feel heat in bother exhaust pipes. I know that you need fuel and spark with timing to make it run. I am knowledgeable in working on Harleys but this one has me frustrated. When I test the coil with my multimeter i zero it out and then tough the primary points and it will give me a reading for a second and then its at 0 along with the secondary. Any ideas would be greatly appreciated. I know i have compression as well. I have not checked timing as far as the cams with the crank but find it unlikely that has moved from and idle and that far that it did not get a valve.
I don’t know but I would check that vacuum petcock again. 3 minutes is about a fuel bowls worth of idle and the feathering throttle then nothing. I hate those things and usually install a blanking plate. Just saying cause I have wasted money on electrical parts before only to find something simple. Good luck.
No luck
I replaced the coil and that made no difference. I have great spark and it will throw you back when it zaps you too. I took the carb off tonight again and took the jets out and cleaned them along with the other ports. Nothing is in the carb for sure now. All vacuum lines on the bike are ok after testing them. It will sputter when turning it over now. It will not start though. I did also take off the cam cover to make sure the chains did not skip and it was a timing issue. They are still tight with minimal wear. I replaced the cam bearings about 1000 miles ago along with slides and tensioners. My question now is it possible the screaming eagle ignition module is throwing the ignition timing off so bad it will not run? Also, I cannot figure out why my tach isn't working while turning the bike over.
There is fuel that squirts out of the accelerator pump when you twist the throttle. I have replaced the coil plugs wires Ignition module crank position sensor, and tested the bank angle sensor. I have great blue spark. It will try and start on ether. (I know its not healthy for the bike). I can not find a broken or shorted wire on the bike. I have cleaned the carb and inspected the intake boots. Still no luck.
zenwarrior
05-19-2007 11:21 AM
Dworrakk
04-04-2006 12:07 AM
