2001 Electra Glide Wont Start
Hey All
Bike won't start
Bile turns over but will not start .but not getting spark
Changed coil, plugs, wires, fuses are good, crank sensor
Traced coil back to ECM. There is a connection before the ECM like a coupling. it is the sample connection that is plugged into the ECM
New Ecm not available, purchased used online did not help new/used part could be bad
Not sure what I am missing
with the ignition on would I get 12v to coil. or is coil get power cycling when you hit start
Any thoughts
Bike won't start
Any thoughts
