"P0113, IAT sensor open/high! error where IS THE LOCATION
Hello i have a 2015 sportster low and i have the "P0113, IAT sensor open/high" error , i resaerched and maybe its the Intake Air Temperature sensor that is either not plugged in, damaged, or broken wire ....WHERE IS THE LOCATION OF THIS SENSOR EXACTLY IN MY MODEL??? please help!!!!!
Looking from the right side (air cleaner side) the connector is on the back side of the throttle body in front of the rear fuel injector.
Here is a link to the 2015 Sportster Parts Manual for an exploded view-
Look at the Induction Module - 2015 Sportster Parts Manual
If the TMAP sensor connection is good, check for pushed out pins on both sides of the connector, you should also check the TPS (Throttle Position Sensor), the IAC (Idle Air Control) and the VSS (Vehicle Speed Sensor) as they are all on the same 5 volt circuit.
The ECU can't tell which of the sensors or connections are bad so it may throw a code for any of them.
The International models also may have the Jiffy Stand Switch on the same 5 volt circuit.
2015 Sportster Wiring diagram-
https://serviceinfo.harley-davidson....96fd299a2!!1!5
3dognate
Milwaukee Eight (M8)
13
06-15-2019 01:07 PM
monishrpatel
10-12-2017 02:40 PM
