SERT Installation question
RE: SERT Installation question
No need to connect anything to the battery.
Once you get your hands on your SERT the manual provides a fairly clear explanation of closed loop operation and the closed loop bias table. By maxing out the closed loop bias table you are in effect adding more fuel when the bike is operating in closed loop mode.
ORIGINAL: ebeattie
Gun runner, I contacted both Chicago Harley and Tucson Harley and both stated that the SERT with part number 32107-01G was the correct SERT for my Bike. Now, if that IS the case that J is the correct SERT for my 2007 FatBoy does that mean the entire SERT is unusable, or does it simply mean that I will have to have a tuner manually adjust most/all portions of the map?
OR does it simply mean there are less precanned MAPS to choose from? As stated both dealers listed 32107-01G as the correct part number for my bike.
I have two computers and will be installing the SERT program on one of them. Yeah its not a laptop, but screw it. I can pull my rig outside!
thanks for the help guys!
waterman7474
01-06-2007 05:08 AM
