Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
nstalled freedom performance longs and dk 587 breather and air cleaner system......I can't find a map that matches which map on fp3 should I use that more closely matches?
The generic doesn't allow for high flow air cleaner....
Thank you
All of our FP3 maps are performed using a high-flow air cleaner save for the stock improved map. You should be able to use the map for Big Shots Staggered and a Standard baffle no problem on your configuration
