Power Vision Gauges
Old 09-23-2019 | 02:23 PM
Nerosync's Avatar
Nerosync
Default Power Vision Gauges
Just curious what others are running or suggested gauges I should be watching more closely with my PV. I have a 19 RGS Stage 1 that I am looking to move to Stage 2 in the spring, but until then running a Fuel Moto map with auto-tune enhancements. Bike is running great, no issues are all, but I am not even going to pretend to be a pro when it comes to tuning. So are there any gauges some suggest and what are the values or things I should watch for?
Old 10-01-2019 | 11:15 PM
1 2 many's Avatar
1 2 many
None . The only thing I look at are engine temp. dont want to burn up my build
Old 10-11-2019 | 06:40 AM
shanneba's Avatar
shanneba
I have a Sportster, I monitor the RPM (no tach on the bike), Engine Temp, MAP and Throttle position.
My steady state cruising at highway speeds (55-70 mph) is usually in the <10-15% throttle range with a MAP of 40-55 kPa.
I keep my bike in closed loop mode in that range to get better mileage.
You may find the Adaptive Fuel Factor Front / rear interesting (if your tune is closed loop and has Adaptive fuel enabled)
A value of >100 is adding fuel, <100 subtracting fuel, indicating your VE values are either less or greater than actual.
A value that is over 105 or less than 95 you might want to adjust your VEs in those areas. (or do more auto tune in that area)
Old 10-11-2019 | 08:03 AM
ROCKOUT Rocker Products
Sponsor
I Monitor temps & F/R knock events
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old 10-11-2019 | 09:42 AM
smitty901's Avatar
smitty901
I have options for a few setup in case i want to know. With the sidecar I was watch engine temps to see how much of an effected it had on on them. Really easy to change and setup what you want at anytime.
Current ones showing.
cruisn
07-17-2019 12:08 PM
super48
04-13-2012 06:55 AM
D.Bob
03-28-2012 03:25 PM
MikeSz
05-31-2011 01:07 AM
MrHog
03-18-2011 07:48 PM
Quick Reply: Power Vision Gauges
