2008 ultra / p2122 p2138 codes
Yes. These codes are set when the twist grip sensor and the throttle position sensors do not agree. This is commonly caused by twist grip sensor and/or wiring/connector issues. See this a lot after internal wiring chafes inside aftermarket handlebars. Also the throttle body connector pins and sockets fret (corrode) and create excessive resistance causing codes and running issues.
hope this helps,
Bob
hope this helps,
Bob
17FLSS (09-16-2019)
17FLSS (09-16-2019)
