same 96 fxdwg, left turn signal only issues
ok on my 96 Dyna Wide Glide, when I got it all worked ok, on the first 300 mile trip, the left turn signal spopped working, at first only at high speed, then all together, but it would work once and a while..... now it never works, I replaced both bulbs, then tested bulbs, then cleaned connections at bulb sockets (still factory perfect), BUT rear one has a crimp connector in the housing looks "fixed" does Harley use crimp connectors? I plan on buying the electrical manual but if anyone has already fixed this problem, help would... help. THANK YOU!
