V&H fuelpak FP3 flat spot off idle
2014 SGS with SE110 tire shredder kit also SE585 cams. V&H head pipe with SE Streetcannons and a Trask high flow air cleaner on the upsized intake.
When outside air temps are above 100 and the bike is good an warmed up. I get a horrible Flat spot off of idle & bad "popping" in the exhaust. Above 3K RPMs all is good.
Cooler temps I do not have this issue.
Have you contacted V&H on this issue ? If not , In your V&H program you can upload your current map to them , then email them , explaining to them what issue your having . In your email , do the exact thing you did here and also include your bike's vin # . They will make the necessary adjustments and send it back . The map they send you will load into a new slot , so if it doesn't work out you can reflash it back to your original map .
the FP3 is not the ideal tuning product for a build such as yours, your bike should be professionally tuned at a reputable shop, TTS or Powervision are going to work the best. Trying to auto-tune a build such as yours is not going to yield the best you can get out of it.
m
m
Bob
mcdaniel52761
2014-2023 Touring Models
23
05-18-2015 06:52 PM
