2019 FXBB DLC connector
As I have read in many places:
"2001-2019 Softail Models Diagnostic connector is located under the seat, attached to the frame by the rear fender. Connector is Light Gray in color, with black rubber plug installed"
But I think it's behind the left cover ... This is what is behind the cover .. Can anyone confirm if this is the connector for the Power Vision? Thank you!!
Thanks for the answer ... But is that the connector for Power Vision? Read that
You may already know that there is another port on Harley-Davidson bicycles for software updates. This port is not connected to the battery and, therefore, any connected diagnostic device that requires the engine to run will not work.
And I don't know how to use anymore, it's the one I have to use ... Is it gray?
