dts ecm no rSP
dts ecm no rSP
2009 FLHX PC5 ,went for a ride today bike went into limp mode,made it home pulled plug on throttle body, cleaned with contact cleaner and put dialectic grease on it. Plug it back in got throttle back. Went to check for codes on the ECM came up code rSP, all other areas came up none, kill switch is on. Bike seems to run alright but can not get any info on ECM through DTS. Also no engine light came on, tried to reset the ECM multiple times same result. Any help would be appreciated.
Are you sure you know what you are doing? Not being rude but if the bike still starts and you say no engine light then something sounds fishy.
Download & read it's from the 2009 Electrical Diagnostics Manual but make sure you read all the pages and look at the pictures.
https://app.box.com/s/wtbxu0nuriqyyr0qqp3o2u9jmiherhd0
