sert problem
Good afternoon all, having problems with sert. when I hook up to bike I have key on run switch etc. when I push for get ecm info it brings up vin#, ecm p/n and present cal ID I have the new cal map file for loading when I try to program it goes to 20% then says cannot program if problem persists contact your hd dealer. any ideas I have vista which I have heard causes problems my wife loaded xp for the sert to run on is this the problem if so her laptop has xp.will that help?
ORIGINAL: doggiedave
Get away from vista.
I had trouble with a usb to serial adapter. Did the same thing. Got the belkin and went right through.
QuentiN
12-15-2007 06:07 AM
