Powervision speedo
Gotta ask though, 4mph Out. You change out the pully to a different size ?.
Wiz 🍻
2156 x 1.03 = 2221 You have changed the ratio by 3% so it's 2156 x 103% =new vss
All credit to member LA Dog (sticky. softail section)
"4. Powervision or other tuner to edit the pulse per km entry for the new drive ratio. New overall drive ratio will be 3% taller, and the speedometer calibration will be 2232 pulse per km for the Breakout with 240 tire. For all other model bikes, just add the ratio percentage increase to your current value. For example, with the 68t rear pulley upgrade it is a 3% ratio increase. multiply your current VSS value by 1.03 and that is the new number. for a 70t rear pulley, 6.07% increase, multiply your VSS by 1.0607 to get the new number. fine tune with a gps as needed. lower VSS by 10 if speedo reads slightly too fast, add 10 to VSS if speedo reads slow. adjust in increments of 10 as needed and re-test."
Q) How do I adjust my speedometer?
A) Speedometer calibration (VSS) can be changed in WinPv under Gear>Speedometer Calibration or on the PV device using Quick Tune. Raising the VSS lowers the reported MPH on your speedo, lowering VSS raises the reported MPH. To correct your speedo, change the VSS by the % of determined speedo error.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
1 2 many (06-19-2019)
