Can bus handlebar wiring connectors.
When adding a tach to my 17 RK I ordered 2 male and 2 female connectors plus 10 pins and sockets, plus couple other connectors. Ended up costing about $100. Pins and sockets were like 2-3 buck each.
Well got tired of it and I spent some time looking for the connectors used. I think I found them but still need to verify..
You can get 25 pins for 2.86 from here..
https://www.digikey.com/product-deta...7-1-ND/1840013
One connector. Digikey shows links to the other side.
https://www.digikey.com/product-deta...675-ND/1839986
If you want to make your own extensions these should work. I've not verified yet but will have some on order soon.
PART: 670-1677-1-ND
MFG : JAE Electronics (VA) / MX19P10K451
DESC: CONN PIN 20-22AWG CRIMP TIN 0.09800 4.90
PART: 670-1675-ND
MFG : JAE Electronics / MX19004P51
DESC: CONN PIN HOUSING 4POS MX19 0.89300 8.93
COO : JAPAN ECCN:
PART: 670-1676-ND
MFG : JAE Electronics / MX19004S51
DESC: CONN SOCKET HOUSING 4POS MX19 1.32300 13.23
COO : JAPAN
PART: 670-1678-1-ND
MFG : JAE Electronics (VA) / MX19S10K451
DESC: CONN SOCKET 20-22AWG CRIMP TIN 0.09480 4.74
COO : JAPAN ECCN:
Both Digikey's and JAE part numbers.
PART: 670-1677-1-ND
PART: 670-1675-ND
COO : JAPAN ECCN:
PART: 670-1676-ND
COO : JAPAN
PART: 670-1678-1-ND
COO : JAPAN ECCN:
