PCIII New firmware observation
I did the 2.2 firmware upgrade on my 07 UC. I did not have any hesitation or pinging issues, just the slow start. Initially I thought the bike started a little sooner, but now after living with it for awhlie, found that it takes at least 4-5 revs to start. With the 2.1 firmware it used to start on the third rev. The bike also seems to run ritcher. At idle I can smell the exhaust alot more that the 2.1 FW. Other than that it runs great. Dynojet tells me that this is a beta version FW, but should improve overall performance. I am going to 0 the first colum on my map to see if this helps, as I have mostly10's in there now on a custom map. Anyone else notice this or is it just me?
RE: PCIII New firmware observation
This is the response I got from Dynojet when I asked if I should install the firmware upgrade.
Steve,[/align][/align]The newer firmware is for a bike specific issue that some customers had on their 07's, with an off idle stumble that could not be tuned out. There was an extremely small number of customers who had reported this issue and the 2.2 firmware addresses it for them. If your bike does not exhibit that symptom there is no need to update. There are thousands of 07 HD touring model with power commanders that don't exhibit the symptom. I would not do any updates if the bike is running well.[/align][/align]Regards,[/align][/align]
Stan Lass[/b]
Dynojet Research Inc[/b]
Technical Support[/b]
800.992.4993 x1116[/b][/align]
Stan Lass[/b]
Solution to slow starting = Harley Davidson triple platinum spark plugs.
No codes or problems after 13,000+ miles.
My '05 Ultra had that issue - hated it - now it starts instantly - before I can even release the button - hot or cold
[IMG]local://upfiles/5166/5D8D655BB6E64EA5BBC9F5EC35831D98.jpg[/IMG]
The slow starting is evidently because the Delphi ECM pinouts on the main connector have changed for '07 and instead of powering the PC with steady +12VDC as historically been the case, the unit now is powered on the fuel pump circuit. I don't know why they couldn't change the pinout and make '07 (and up?) specific units but for the fact that would necessitate twice the Harley part numbers. That is perhaps a bit unreasonable to ask of them, especially when everything still works as-is. Just start the bike while the fuel pump is still whirring or crank a couple extra revs until it starts to whir again. No big deal for me either way. It's no TM/AT, but for the money I'm way more than happy.
Wait. I'd rather they did make '07-and-up-specific units. They should fix the wiring in the main connector while incorporating the O2 eliminators there as well. Then there would be no complaints of slow starting and we could all leave the sensors connected to the harness to keep everything clean in the connectors for future possible use.
ORIGINAL: iclick
Just start it before the check-engine light goes out.
ORIGINAL: gabhart
They need to fix the stinkin' slow starting!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
WS6 Formula
09-26-2007 04:43 AM
