Check Valves 99-01 Touring
I found a gas leak in one of the two check valves found on 99-01 Touring Models. I planned to replace it but an uncertain if it connects to the fuel pressure regulator or something else.
1. To what does the forward check valve connect?
2. And does the rear check valve connect to the fuel pressure regulator or something else?
G'day CAP,
welcome to HDF.
Now, for your orientation. Go down the hall on your left to the 1st room. No, wait. That is where Izzo interviews the gals. The 1st room on your right. That is where the commissary is.
We have our own pub .
**** ON THE SERIOUS SIDE ****
Have A Great Day Mate,
BuzzCap7
welcome to HDF.
BuzzCap7
CAPTUSNESQ (11-09-2019)
It will allow you to see diagram of potential part and part number.
Use a real computer in order to best view.
http://partsfinder.onlinemicrofiche.....asp?make=hdmc
