FOB HELP
RE: FOB HELP
Runcode3:
natewat is correct..............new FOB will need to be assigned at Dealer. Same as new bike setup:
Set-Up and Pre-Delivery Process
During Set-Up, the technician will need to use Digital Technician to assign the Hands Free
Fobs. The new bar code reader should be used to enter the 24 character number from the
bar code on the fob. Once assigned, the fobs should be tested immediately using Digital
Technician. The fobs have to be assigned
and the PIN must be assigned to enable the
system. It doesn’t matter what order this is done in. Since the system is self-arming, it is
absolutely important that the customer has the PIN and knows what to do (keep card) in the
event that the fob is lost or misplaced.
Tech Tip
: Save the sheet that is attached to the carton when vehicle is uncrated and scan in
the bar code to fill in the VIN when starting the process with Digital Technician.
