2011 fuel pump system removel street glide
Live in costa rica so every part cost double.
Bike sent P1356 code rear cylinder no combustion.
Plug fires fine. If I pump the gas I can keep it running, but runs hard, not good enough to leave garage.
The issue is there are no videos to remove fuel pump system for 2011 street glide. The manual is also very vague on removal. Just parts replacement after its out.
Second question im nor sure pump is the issue.
Im thinking about bypassing the pump with 12 volt inline fuel pump. Just to check if fuel pump is not working.
If you sure it wont work please advise. if not a video of 2011 street glide fue pump removal, would help this ole vet out.
Thank you in advance
Hello Samctimbo,
You should check the condition of the fuel lines inside the fuel tank as that may be your problem?
Read this thread https://www.hdforums.com/forum/touri...-on-ultra.html
And this thread https://www.hdforums.com/forum/dyna-...el-line-2.html
More on checking the fuel line for leaks https://www.hdforums.com/forum/touri...tor-issue.html
Here are the instructions for removing the fuel pump https://www.hdforums.com/how-tos/a/h...-filter-414296
Keep us posted on your progress.
drspencer
09-19-2012 12:02 PM
