SERT map # for a 0 7 road king ???
Has anybody tired a sert map for a 07 road king I put a sert in and I would like to download one of the maps in to the ecm but I am not sure of which one to use. I would like to see which ones you use and how you like it.
25deg Injectors
SE Air Cleaner
Rush Slip Ons
RE: SERT map # for a 0 7 road king ???
You can certainly try maxing all the cells in the closed loop bias table and see how it works. I'm using calibration 67 in my Dyna and it's a lot different than cal 78, so I can't say what will work for you. I highlighted the entire table and incremented until the highest cells were 798 and that fixed the surging I was having. It doesn't cost anything to experiment and you're not going to hurt anything by going richer except maybe a little gasmileage.
ubreal
07-02-2007 02:15 AM
