fp3
I'm not really sure what you are trying to do here but -
If you want to DOWNLOAD the base V&H map again then you use the "Search for a map" option on the main menu.
If you want to COPY an existing map into an empty slot - click on the empty slot and it will ask which Slot/Map you want to copy from.
