Direct Link 1
RE: Direct Link 1
It is basically on the same principal as a SERT, It is made by technoresearch and appears to be a less expensive option then the SERT you need to have it installed by a tuner, I do not think it comes with canned maps like the SERT. But the places that use them are usually very extinsively trained to tune with the direct link.
you can check it out and find a certified tuner at www.technoresearch.com
I was going to have my bike done this way but went with the SERT so I could ride the bike on a canned map before I had it dyno'd otherwise I would have went with the directlink.
