Will not Shuit-Off
Will not Shuit-Off
Well I have a 2005 Redneck Mutant with a buell Lightning engine.
The bike is great runs strong but it is having a weired problem.
When turning the key on, and putting the switch into run the starter starts spinning then you press start switch and the thing fires rught up, but when you turn the key off put the switch to stop the starter is still spinning , need to disconect the battery in order to make it stop.
We checked the ignition and thats seems to be fine nothing is crossing, the wires seem to be ok.
What could be causing this problem?
Need help.
Thank you
Need help.
Thank you
Jamie Hart
07-28-2019 03:07 PM
