SERT ?
hey guys
07 Bobber
V&H Big Radius
SC A/C
SERT
I want to install all that stuff this weekend, I'm saving the SERT for last. I take it once I install the SERT, I need to install a file or she wont run? Simple question, I know
I think theres files in the sticky above to get me by for a week until I get the dynotune?
I just want to beable to run the bike to make sure the pipes aren't leaking etc
that and I can't wait to hear the new pipes
07 Bobber
V&H Big Radius
SC A/C
SERT
![Wink](https://www.hdforums.com/forum/images/smilies/wink.gif)
The race tuner software gets installed on your computer, not the bike. Using the software, you download a calibration file to the ECM on your bike. In your case, calibration 67, file 159AE003-A1 would be the right one. After you get the pipes and air cleaner on, you can start the bike without doing anything with the race tuner if you just want to hear the pipes. I wouldn't ride it for any greatdistance without downloading the calibration file, though.
Read the manual before you attempt to download a file to your bike to make sure you understand how it works.
Exactly what he said!
The only thing I would add is...Iwould install the SERT map #67 first or at least see if the program works with your computer (if you have vista there might be a big problem) and the SERT reads your VIN# correctly etc. It would be a real pisser if you went through all that work and you couldn't install a base map.
thanks guys, I hope to dig into this project tomorrow. I'm goina take my time. do my 1000 mile check, and clean the bike shes on my lift
can't WAIT to hear those pipes!
I have XP Pro, have people run into problems with their SERT not working? since there are stickers all over it saying once its installed it can't be returned...
I have run into a big problem with windows vista....I used to use windows xp pro and then did a full install of windows vista and ran into big problems! Switched back to windows xp pro and all worked well!!!
You should be fine running XP Pro.
Good luck and keep us updated, I am sure you will be very happy with your results.
Be sure and use map #67 that should get you by until you have it dyno'd
ORIGINAL: MetallicaMatt
It is the "dongle" that "mates" with your bike. The first time you use it to load a calibration file it will write the VINto an onboard PROM on the dongle. That is not reversable, so once it is "mated" it will only work with the bike with that VIN.
my SERT didn't come with any cords
....was it supposed to?
