PC maps to a PV?
I would definitely give Dynojet a call on your need for a base map. They should be able to put one together for you. Or tell you how to import the one you have. Could it possibly be as simple as >Load File >Send Tune to PV?
The File Menu in WinPV has an option to "Import Power Commander Map" and the help file has how to do it.
To Import a Power Commander Map File (.pvm;.djm)
1 Make sure you have a tune loaded.
You must have a copy of the original tune loaded before importing a Power Commander map file.
2 Select Tune Info from the Tune Items manager and click Description.
If the Strategy is 9, 44, or 218, the Power Commander map file will not import. When the existing VE tables are RPM versus MAP (KPA), you will not be able to import Power Commander map files.
3 Select File >Import Power Commander Map.
4 Select a file to open.
5 Click Open.
6 Click Yes to swap the Front/Rear import order.
Or
Click No to import as shown in the window.
The Import Complete window will appear. This window will explain which tables were imported where, how many cells were switched to 14.5, and how many imported values exceeded the VE Table range.The maximum value in a cell is 127.5.
If you see 127.5 in a cell, you know the imported Power Commander map tried to exceed that value.
7 Click OK
5 Click Open.
Or
7 Click OK
