Thunder Max On or Off
RE: Thunder Max On or Off
Funny, my wife comes in through the garage and I have the pc sitting on the floor hooked up to my bike. The Vista laptop would not recognize it. She thinks I'm a moron. I am getting scared that she may be right--check this out if you have the TMAX, I just installed mine 2 days ago and only was able to test it for 30 miles or so. I read nothing but possitives on this set up and now all hell is breaking loose. Anyone around here have any problems?http://www.cvoharley.com/smf/index.php?topic=14269.0
G'day Roodog and others,
They are right about the benchtop equipment. I had no computer, let alone anything else... so.... I asked the dealer to install a map that I selected before taking delivery of the unit. He did this and also changed the speedo calibration as the map most suitable was for a FL touring bike, remember that we get a smaller rear sprocket so the speedo will be the revers of what you expect...in other words it will read 98kph when you are doing a true 100..... not that the cops will beleive ya !! anyhow he also reduced the idle speed and then it was plug and play (as the yanks say). I got no A/T as it was $700 EXTRA , but don't need it .. bike runs PERFECT. The I.T computer geeeke at work said "vista program" would not work with the software, so I eventually bought a used (old) laptop and have since reduced the "warm up idle speed" and the hot idle speed even more. I won't say how low or I'll get flamed ..... PM me if ya want full details.
Graham (Brisbane) 06 dyna.
I have a new laptop with vista and the t-max software works fine. on the t-max web site they have a file that is in their instruction on how to install the software on Vista. I have had no problem at all with it when linked to the ecm. Also I would like to find out who here has the firmware 4.5 upgrade. Ride like the wind if you can............................................... .....Jamsdude[sm=biker2.gif]
You can buy a power supply from thunder max to power the efi unit, so it can be programmed before it is put on the bike. it's like $85.00 ,they show it on their website.
as long as you have a lap top or pc in your garage, you shouldn't need it. setup is pretty quick as well.
