Voltage divider for 2007's to cool engine?
It has been posted on some boards about using a very cheap and simple voltage divider to make the O2 sensors readjust the Air Fuel mixture from 14.7:1 to 14.2 :1 thereby making the motor run a little cooler. Has anybody tried this and can verify its effectiveness.
Here's one link I found expaining it in more detail.
http://www.nightrider.com/biketech/h...olt_divide.htm
Sounds like a good idea. Somebody might want to jump on this and create an adapter plug for stock O2 sensors. I'm sure the part could easily sell for $40 with a manfacturing cost of less than $5. It would only work in the idle and cruising ranges since the narrow band sensor only work in that range. However, since the bike runs in this range a majority of the time it should result in a measurable difference in temps.
ORIGINAL: Z_Stingray
grasscat
10-09-2018 10:21 AM
speakerfritz
05-20-2011 09:23 PM
GAguy
13
01-14-2010 08:47 AM
