fuel pump not turning on
14GuineaPig (02-02-2018)
Could be the first one just ran out of its life, and the second was a bad apple from the get go; dying quickly. Third times a charm. Isn't there a warranty on the replacement pump?
Any time an electric motor fails you should do a voltage drop test on the circuit. You can easily hook up a 12V bulb in place of the pump and be sure it is dropping battery voltage across the bulb. If an electric motor doesn't get the proper voltage it overheats as it tries to draw current.
Performing a voltage drop test IS NOT the equivalent of just checking for 12V at the connector without a load on the circuit. That is where the majority of service manuals fail to diagnose bad circuits.
