Front cylinder turns into an air pump - NO CODES
2013 FLHTCU with a stock 103.
Rolls & shifts ok when going easy but when I get into her at any RPM the front cylinder quits firing & turns into an air pump. When I get off the throttle she'll fir e & roll on. Starts like an old John Deere.
WILL NOT accellerate heavy in any gear. ECM gives no codes.
Been at the Dealer for 4 weeks now & even after thee SE Stage 1 upgrade, checking all wiring, sensors & running diagnostics, they still don't know what's up. Going for a new ECM next.
Little help!!
Little help!!
well if it will run gently, then i would not expect the ecm. the ecm only calculates info from other sensors. how did they run diagnostics??? sitting on the floor ain't it, they need a rolling data log under the exact same conditions, remember, under load, data is diff.
what can kill is map, tps, cps and even injectors. that said, the fuel pressure regulator can be going crazy when longer on-time is called for. another killer is the coil loading, as speed goes up so does coil current and if the unit is not up to snuff, weak spark.
Dealership told me yesterday that they tried the new ECM & there is no change in the way she runs. I asked the questions in your reply & they told me they ran diagnostics under load & had checked all the items listed. They also said they have been in contact with HD directly for assistance but with no error codes showing they are as dumbfounded as the Dealership.
It appears they will now start “guessing “ as to what is wrong.
Going on 5 weeks in the shop with no clue on what to do.
well, i do not think the dealership is up &up. if they are data logging, they can see what is happening anywhere from throttle sensor to fuel control. they need to be looking at sensor input but maybe your model does not allow that but it should. there are 5 layers to the system and maybe they can only see the first two.
when we had issues with equip offshore, the diagnostic tool will show the ladder logic as it is happening.
but the new ecu would eliminate the ecu. have you re-routed any wires?? if there is emf being induced into the system, the computer will go stupid since it can not tell what the command is.
do they have an o-scope? they might want to look at the ign wave forms.
Doobie60 (10-18-2017)
HDF Tech
01-19-2006 04:58 PM
