Trying to diagnose IAT code P0113
For years now my bike has throw the P0113 trouble code. IAT sensor - high input. It never bothered me, as driveability was perfect. Had it Dyno'd after cams and it ran great. I ignored the code. Last year I did a big bore and heads, really pulls hard. A couple of days ago I washed it at the local car wash, it ran a bit rough after that and even more so yesterday. I pulled the codes and again I got P0113 but in addition I also got P0374, crank sensor. I thought the connector might have gotten wet so I checked it this morning. It was wet with something, so I cleaned it out and sprayed some WD40 in it. I cleared the codes and rode around the block. It's running so poorly I thought I might not make it home, but I did. Checked the codes again, the crankcase code did not reappear. The IAT code did though. When I did the big bore I replaced the IAT sensor with a new HD part, still threw the code. Specifics are 05 88 touring, now 95". Fuel Moto USB tuner, untouched sine last Dyno tune. I'm trying to diagnose that I AT sensor. Short of replacing it again, is there a way to bypass it for diagnostic purposes? An important clue came today, when after clearing the codes I got a different part number after the trouble code, this time 32915-05, which is the ECM part number. However, I found some online posts that says that happen after you clear the codes but I don't know. Where to start?
Hausguy
08-21-2017 10:30 AM
