ECU Dead?
I took the PClll off the bike and hooked the ECU back to the stock harness and the fuel pump did the same thing as it did when the PClll was hooked up. I did notice that when the Ignition switch is on for a bit the exheck engine light flashes rapidly and from what I understand that’s a failure to communicate code?
Well PROBLEM SOLVED!!! After a night of trouble shooting damn near every wire running from the fuel pump relay and the ECU... it was the roll over sensor. When I took it off to run the connectors for the tuner behind the battery box I remounted it and didn’t get the alignment pin thing seated in the hole it’s supposed to be in. So when I went around the vehicle on the highway I leaned over and the little ball inside the sensor must have moved and tripped the sensor. I feel really dumb but it’s all good. I now have a spare ECU so Incase it ever does go out I’m ready!
AMB2710
10-11-2021 10:45 AM
dnshat
16
09-20-2014 04:56 AM
just plain john
08-28-2013 09:08 PM
