NONE
RE: TMAX is it worth changing? Opinions Please
I have it, changed from a PC III that I couldn't get tuned quite right on the dyno. I like the tmax, wouldn't go back. But if it's working fine now, then why go through the expense and all the trouble? I wouldn't unless maybe you plan on changing things in the future. The only reason I changed is because I couldn't get the PC dialed in quite right despite all the dyno runs.
ORIGINAL: bob2002
I have the PC IIIwhich I have dialed in pretty good,MPG 41-44,good throttle response,decent power. I've read so much about theTMAXthat I'm wondering if I can do better,anybody thats switched I like to hear your comments. Thanks
A service writer at the local HD shop has a Dyna that has dynoed at 104 TQ and low-90's for HP, but he has 2-into-1's which will out-perform my slip-ons. I like those numbers, and if I could approach 100 TQ and mid-80's for HP I'd be happy.
ORIGINAL: chriscalabro
I am going to T Max because I can't get my sert dialed in. I would probably not bother if the bike is running good. As good as the feedback has been on this product you never can be sure whenever you make a chnage.
Regarding the True Duals....here's a simple test. Put your m/c on the dyno and get it warmed up. Be sure that warm-up enrichment is at zero before all runs. Have a piece of 2 x 4 board on hand.
1. Do a 100% (WOT) run on your m/c.
2. Don't make any changes and do another 100% (WOT) run with the 2x4 covering half of the right-side pipe.
3. Plot both torque and hp curves on the same screen.
I'll bet the 2nd dyno run, (board over exhaust), produces more HP and Torque. The Rinehardts are notoriously poor at allowing air out of the cylinder. By covering the exhaust, air in the cylinder is better organized and can flow out faster. It's not about the size of the hole! It's how efficiently it gets used.
I would not replace your True Duals. In October I built a 2007 110" SE Ultra. Stock heads ported and flowed, JE 10.5:1 pistons, Mackie 598 cams, and T Max w/Auto Tune. The guy had SE A/C and True Duals tuned with a SERT to start with.
He was advised by friends to replace the duals with a 2 into 1 and we did some dyno runs with the duals and then swapped out for V&H 2 into 1 (blue proof) and made some more dyno runs. I thought we would see more but I was surprised; 2 HP & 2 lbs tq difference was all we got. I always run 2 into 1s on my bikes and they are IMO the best performance but based on that SE 110" I would say you won't gain much for the cost.
Thanks FXRP:
You just saved me alot of money. I have been trying to decide on True Duals versus a good 2 into 1. The diffeence in cost is at least half the price as I already have rush slip ons I could use.
Just curious, is there any difference between True Duals and the 2 into 1 when it comes to reducing the engine heat under my *****....[:@] ?
ORIGINAL: cruiser85257
Thanks FXRP:
Thanks FXRP:
A lot of my clients like the duals on baggers because there's a pipe under each bag. I run 2 into 1 on my baggers because I prefer the sound and I think they are a better system.
