Howards hog horns relay install
Hi everyone,
I recently purchased a Howards hog air horn set they look great on my 06 road king I at the point where its time to install the horn relay the instructions the manufacturer gives are vague. Is there anyone who has this set up and can shed some light?
Bub
Bub
It's going to be the positivewire attached to the horn. You have to extend it to the relay.
You've got a wire from the relay to the negative battery terminal, one to the positive terminal, one from the positive wire I just mentioned to the relay, and the fourth goes from the relay to the compressor positive. Then run a wire from the compressor negative to the battery negative post. Refer to the relay instructions for which one is which.
IAMSWUTIAMS
09-03-2008 07:16 AM
1200, air, harley, hog, horn, horns, howards, howrads, install, installation, installing, instilation, ironhead, sportster, tips
