Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
What is this hole for?Just replaced the fuel lines for this 1997 Sportster 1200. Everything is ok except I'm leaking a good amount from this hole. Is there supposed to be a plug or is it supposed to be there?
That is an air bleed to allow the diaphragm to move back and forth to open/shut fuel flow.
If fuel is coming from that hole there is a hole in the diaphragm.
Was the replacement valve new from HD?
Bob
Bob
Ok that makes sense. No it's not. The valve is what I took out of the tank when cleaning up the fuel lines. This bike has been sitting for the last 12 years, and the fuel lines were all rotting off. So I emptied out the tank and replaced the lines. Problem is I can't find a rebuild kit.
