Ignition Switch Electrical Issue
Hey fellas,
I'm a new rider and a bit uneducated about the electrical diagnostics of my bike, but I have a slightly annoying issue on my '14 Iron 883.
Straight to the problem: I insert the key and turn on the bike. Lights come on, fuel is injected per usual. However, nothing happens when I press the starter switch. After a couple minutes, the switch miraculously works and the bike starts up fine. Sometimes the switch works immediately, sometimes it doesn't. What is even stranger is if the bike is put in neutral, the starter switch will work immediately.
Right now I'm planning on checking the fuses, but I don't really know what else to do. I'm assuming the battery is fine since the lights come on. I tried looking up tips in the $60 service manual I bought only to find out I'd need to purchase an additional electrical diagnostics manual, which may be too advanced for me to read to begin with.
This issue started happening after a major storm. Typically the bike is open to the elements of the weather since I'm a college student, but I made sure to cover it up and protect it.
If anyone has any tips or suggestions I'd greatly appreciate it.
Thanks,
Anthony
Thanks,
Anthony
Do you have a multimeter? Something to measure the voltage in your battery? It should be 12.8 volts without the bike running. The lights will come on even if the battery is not 100%.
How old is the battery?
Do you keep the bike on a Battery Tender? How long does the bike go between rides or charges?
If pulling in the clutch lever is different than having the bike in Neutral, I'd say you may need to give your clutch adjustment a look-see as well.
