Which file??
Which file??
I have a 2012 Street Glide 103 with stage 1 air cleaner, rinehart slip on exhaust, gutted cat, and Andrews 57H cams with the 4 degree advanced gear on it which is supposed to make it similar to the SE 204 but with more lift. I loaded a base map into the bike, and it seems to run fine, but I want to make sure I have loaded as close as possible before having it dyno tuned. So, my choices are:
Application 2009 Touring
Configuration 1690 Touring stage 2 with SE-204 cams
components:
SE air cleaner
SE big bore cylinders
SE 204 cams
SE exhaust
ACR is on
or:
Application 2010-2013 Touring
Configuration 1690 Stage 2
components:
SE air cleaner r heavy breather
SE 204 cams
SE exhaust
ACR disabled
Or maye neither one? Any insight would be great!
components:
SE air cleaner
SE 204 cams
SE exhaust
ACR is on
or:
components:
SE 204 cams
SE exhaust
ACR disabled
components:
SE air cleaner
SE 204 cams
SE exhaust
ACR is on
or:
components:
SE 204 cams
SE exhaust
ACR disabled
components:
SE air cleaner
SE 204 cams
SE exhaust
ACR is on
or:
components:
SE 204 cams
SE exhaust
ACR disabled
I wouldn't worry too much about the base tune anyway, if they are going to dyno tune.
