Power vision auto tuning
Today I finally fired up my bike after installing my cr575 cams and 70t rear sprocket. I am currently using fuelmoto's target tune that they sent me and the bike runs fantastic. I don't know which helped more the pulley or the cams but things are running smooth as silk. I still have the auto tune option but not really sure if it does a a lot with the target tune installed right now causing my af sits right at 13.8-14.2. Wot pulls bike goes to around 13.2-13.5 range and it seems to be good. Other than being unsure about how close my speedo is (2367 pulse per km) things seem to be good. Should I go a head and auto tune anyways or would one say what it is is good.
Today I finally fired up my bike after installing my cr575 cams and 70t rear sprocket. I am currently using fuelmoto's tts tune that they sent me and the bike runs fantastic. I don't know which helped more the pulley or the cams but things are running smooth as silk. I still have the auto tune option but not really sure if it does a a lot with the tts installed right now causing my af sits right at 13.8-14.2. Wot pulls bike goes to around 13.2-13.5 range and it seems to be good. Other than being unsure about how close my speedo is (2367 pulse per km) things seem to be good. Should I go a head and auto tune anyways or would one say what it is is good.
If he does not know the difference between the Target Tune and a TTS MasterTune, I think he should bring it to a good dyno shop.
JMHO.
stal94gt
14
03-20-2017 05:47 AM
Lance Arrant
05-09-2015 09:14 PM
